Oced Normal 2500+ @ 2.4Ghz , i wos using a tornado 92mm High Noise High Performance Fan.. But i changed to a 80mm low cfm fan..*(Low noise) on my SLK947U, the Temp of CPU AT full load is 52C, Is it too hot? 1.75V
Originally Posted by Crash IMO - I always try to keep AMD's under 50c. I find they run better. |
Originally Posted by dongchen_han Oced Normal 2500+ @ 2.4Ghz , i wos using a tornado 92mm High Noise High Performance Fan.. But i changed to a 80mm low cfm fan..*(Low noise) on my SLK947U, the Temp of CPU AT full load is 52C, Is it too hot? 1.75V |
Originally Posted by Xavier1421 I agree with crash, sometimes temps over 50 lend to instability and what feels like a slowing down of processes... if 52 is the all time high your system gets, you're ok I think for now. City of Heroes crashes at 2.6gigs running 50 degrees...(the water system is slowly getting warmer and warmer...damn dust in the radiator) |
