1 - 3 of 3 Posts
i have a nvidea geforce fx 5200 idk how high to oc it i got it to 270/502 idk if i should make the core higher or memlower what will benefit me more higher core or higher memory?
Try different combanations and then bench mark eachone to see what works best. That is the best way to do it since no one can really tell you what will be better for you since it always varies.
get power strip that worked for my other computer really great i was getting 500 frames in medal of honor.
1 - 3 of 3 Posts
