Status
Not open for further replies.
Custom 62mm TEC Water block
114K views 679 replies 46 participants last post by  flak-spammer
#1 ·
Im make a 62mm water block for TEC's
This is a pic of the hot side channels ..
yes i know there's a corner missing .. oh well you live and learn .
Preview image for a collapsed post.
#11 ·
Originally Posted by cuy50 View Post
Looks restrictive! But should cool like a beast! I can't wait for more pics.
i would think this block is very UN-restrictive actually
Dont for get that when making a TEC block you heed to ensure all of the block gets roughly the same flow becasue the heat is roughly = arross it's surface.
this is very different compared to a CPU block which pritty much only cares about the centre.
#12 ·
Originally Posted by flak-spammer View Post
Well the more surface area the better imo. I just hope the channels are the right depth to retain a high velocity through the block (because that's going to pick up a lot of heat with that surface area). I suppose it's up to to testing.
i would think id be better off with shallower channels to get the velocity up .
i dont have a very good W/C system so everyone should get better results than i do.
it's gonna take me a while to make the top for this thing
#14 ·
Personally I think it'll work pretty good it's roughly the same design as a lot of the professional TEC waterblocks. Only difference is it's made of copper
Thanks you can stay
i might have to make you one with all it's corners
i can't stop looking at it .. it's so nice.
The cold plate is on the mill right now ...
#17 ·
Hey it's looking good!..
..Your right if you keep the lower part shallow it should up the velocity a little.
Can you not get a little piece of Delrin there to make a top? It machines really nicely. HDPE might work to though, all I've ever done with it is drill and use files to shape it, but it didn't burn with a drill bit so maybe a mill will work to.
#18 ·
Delrin is 4 times the price of HDPE here .. so it's completely unrealistic when i have to buy it by the square meter.
HDPE is an "engineering" plastic and can be machined.
However
im gonna see if i can make an acrylic top for this thing now. as i would really like to beable to see the inner workings of the block .. Im sure this will be a bad idea though cos of how flexible acrylic is .... so im sure im wasting my time.... it's all learning for me though
#20 ·
Originally Posted by ChielScape View Post
dont forget the cutting fluid when doing acrylic, and take it slow.
maybe these pics will give you some more ideas
obviously you'll want the large stepped one.
o yes the cutting fluid and coolant system is MOST important in getting a good finish with anything..
nice pics .. thats a lot of bolts !
#24 ·
However
Ouch a whole square. I hate to say it but you all need a flea bay there. This guy ships world wide, it would probably be to expensive to NZ but you might want to check it out. He's always getting in odd sized lots that he sells pretty cheaply...Delrin Virgin white sheet 0.375 x 6 x 27.75 CNC (3.3F)
A o-ring would be good with acrylic if you can cut a groove for it.
If you end up using HDPE or Delrin automotive water pump gasket with a little red Permatex on each side makes a real good one shot gasket. You can get short rolls of water pump gasket here at the auto shops for a couple of dollars.
#25 ·
i of cores could make it out of copper but that would add 1/3 to the cost and weight .. but i bet people would love it
Status
You have insufficient privileges to reply here.
