Any particular rad you are referring to? All rads are not created equal.This big enough for 12700k and 3080ti/6900xt?
The OP is not looking for a CLC. What a CLC is incapable of isn't really relevant.my single aio 360mm can't even cool properly my 12700k at 1.3v
Well… noise isn’t that too big of deal.Any particular rad you are referring to? All rads are not created equal.
Do you have noise concerns? If you do, bigger may not necessarily be better when you start looking at the multi-rad setup you are going to need.
What case is this going in? That is a huge part of the equation.
What is the rest of the loop going to consist of? You can buy all the rads in the world, but you are going to need a pump capable of moving the liquid through them, etc.
Oh, boy.....Calm down.
A clc perform most of the time the same or better than a loop it being proven in the past 10 years.
😂😂😂😂A clc perform most of the time the same or better than a loop it being proven in the past 10 years.
The non sense? Look at the benchmark of custom loop kit. Many more on youtube and other review website.Oh, boy.....
You believe whatever you need to to get you through the day. But don't share the nonsense with people actually trying to learn.
Going out of your way to build a ****ter CLC doesn’t justify a CLC being just as good as a custom loop.Use a crap pump and crappy rad and you got worse temp
The Corsair rads are actually HWL L-Series rads with the Corsair name slapped on the side. In the US, the markup for that Corsair sticker is steep, around 50%, while in other parts of the world the Corsair version is cheaper. Do some shopping to see what holds true with where you are.Well… noise isn’t that too big of deal.
I was looking at the 54mm thick 360 rad Corsair had on their site. Since standard are what?…30mm avg? It just used for gaming and not trying to get top benchmarks.
Since right now I have a noctua d15 on cpu and Gpu is air also. When gaming all heat is from Gpu. I thought about just a factory hybrid kit for the video card and leave cpu on air.
Say like a 10 min bench like r23 I heat up to 77-81c with air. Cpu fans and case fan curve I set so they are 100% at 70c cpu temp. In the 50c cpu range cpu and case fans at 50%.
In games it jumps around but usually averages 50-60c. But don’t know how much heat is soaking from Gpu below. You can feel the glass is quite warm. If I had a metal panel instead of this glass I would have measured and cut a hole it side and used some sticky foam and matched it to the side exit on Gpu. Exhaust most of that air out of case like that. Just weighing things out to as what I really need.
Case is a cooler master h500. Says it can fit 360 in front and 240 up top.
The fact of the matter is, if you don't know enough about a subject to realize how ludicrous the "proof" you got fooled by is.......you shouldn't be trying to give advice on said subject.Going out of your way to build a ****ter CLC doesn’t justify a CLC being just as good as a custom loop.
My PS5 console is just as good as any custom gaming PC out there, here let me compare it to a PC with the worst parts I could find.
As I said, just ****ing total nonsense
The fact that you keep referencing rad thickness isn't helping your credibility here.....if you go back to my first reply i said a 360mm is not enough for a 12700k. And that perfectly valid.
Where the part i don't know what am talking about?
A triple thick 360mm would not be better.
And i just proved that my point was valid that a aio or custom perform mostly the same if they have the same thickness video up. You get a bad flowing radiator or a overspeced pump like most of them are and you may end up with a worse performing loop.
