550 W PSU enough for Quad core ?
965 Views 12 Replies 10 Participants Last post by  The Master Chief
I am about to buy a GIGABYTE MA-770 US3 rev2.0 motherboard , and an AMD Athlon II X4 620 .
I am asking that my 550 W psu will power those components .
My Pc : *Amd Athlon 64 X2 4200 @ 2.70 GHZ
*Biostar NF-560 A2g+ AM2+ ready
4x1 GB Transcend Revolution 800 Mhz gaming Ram
Powercolor Ati Radeon 4870 1GB Gddr5
550 W MS-Industries Power PSU (18A on 12 volt rail)
+3.3 V - 28 A
+5 V - 34 A
+12 V - 18 A
-12 V - 1 A
-5 V - 0.5 A
+5VSB - 2 A
It has 3x12V Rails with each 2 molex connectors ( 6 molex )
and one 6 pin pcie connector
I am on low budget , so a new PSU would kill me :/ !
1 - 13 of 13 Posts
It will work, it won't draw much more power as your current setup. Never heard of that brand PSU though. It has 3 x 18A on the 12v?
As Andy said, it won't be a dramatic power usage difference. I think around 40W at most (probably a lot less).
Check out my rig.
In other words, yes, it should work. If your PSU has about 60A on all the 12V rails, you're in the green.
^It's impossible to have 60a on the 12v rail of a 550w PSU.
A PSU is the most important part of a PC - if it's cheap and it fails, it could take out your whole system. That being said, you could get away with it for a little while, but once you have the extra money, definitely get a quality PSU.
Running my system @ 450w and everything is overclocked. If its a quality brand PSU then it will work just fine. Newer heard of your PSU tought.
Obviously. I just didn't want to type out a paragraph explaining that W=V*A, etc. If it's RATED at 60A, he'll be good to go. There.
I'm not so sure guys. Why do the specs only mention 1 12v rail? It sounds to me asif he's got something confused.
I'm sure a psu with 3 x 18amp would have more than 1 pci e connector aswel.
It can have 1 PCI-e connector with those specs, if it's a cheap model. Which it probably is.
Okay .
There are 3 X 12 V rails , and all of them having 18 A ( 3 X 2 molex ) .
+ 1 x 6 pin pciE ( which i use for my videocard ) + 2molex to 1 pciE 6 pin connector ( for my videocard )
I am not sure . This PSU was not cheap , but not expensive either .
1 - 13 of 13 Posts
