1 - 20 of 21 Posts
Hi guys im thinking about trading my 550BE X2 3.8GHz + £50 for a stock nearly new Phenom II 945 X4 3GHz.
What do you all think? Should I do it?
haha, ur considering it now xD, ill get some info if i can find anything, assuming u will benefit from the 4 cores i'll say its a good deal since there both used and the 945 isnt that old
edit: just found this thread, wooo i can use the search button
http://www.overclock.net/amd-cpus/61...-550-vs-p.html
I think you are good where you are at. People have been telling me that you wont be seeing much gains from a 720 to a 955, especially in gaming when most games only take advantage of 1 or 2 cores.
Also the 6 core CPUs are due next year. You can upgrade then.
Edit: oops someone is gonna trade you for 50 pounds? I dont know if thats a good deal since Im from the united states, but if that doesnt seem like much, id say go for it
Efficiencycionado
do it!
especially if you like gaming while doing lotsa or at least a couple of minimized apps at the background.
im really tempted but not sure if i can live without my pc while the cpu is in the post.
also im a bit tight on cash at the mo. I can afford it but its probably better spent on bills or some crap like that. lol.
Originally Posted by JMT668 View Post
na just the 550be that i would be trading.
would the new chip work with the same os install?
Should work.
Efficiencycionado
Originally Posted by [email protected]'D
yess it will work with the same os. and I dont think its worth it, A none BE phenom in my eyes is pointless, Sell the 550BE for £60 + £50 you have and buy a used 955/965
most of the phenom 2 chips maxes out at the same clock speeds. BEs are just easier to oc.
i would trade my 940be and a couple of bucks for a 945 just to get the ddr3 feature.
the only real benefit of BEs is when you're using non-conventional cooling.
show me a 945 no ES clocked to the same speeds as a 955/965 i.e <4ghz> 24/7 and I will shut up
Why have a Fiat *945* when you can have a ferrari 955+
Efficiencycionado
i can get 3.7ghz with a pure fsb oc with my 940be. i couldn't get it to 3.8ghz compared with multi and fsb coz my components are limiting me. but i know i can do more. and i bet a c3 945 would oc more. it's just harder to achieve.
and just take a look at intel cpus. the i7 920 maxes out just about the same as an i7 965/975 extreme editions on conventional air cooling.
besides, what's a 100-200mhz of clock speed advantage of 2 cores over 4 cores anyway?
yeah but Im 100% sure this isn't a c3 stepping 945. But w.e, Just remember why make things harder for yourself with a non BE.
Ohh and Remember Ferrari FTW
1 - 20 of 21 Posts
