1 - 8 of 8 Posts
Hey,
I'm building a computer for my friend and everything seems to be ok except for one thing... the vga and cpu combo...
So here are my two choices...
I5 760 + gtx 460
or
Phenom II 955 + (2x)5770 CF
The price is pretty much the same (15$ difference) and the guy says he<ll buy either one...
So I need some help choosing
Thanks in advance!!
__________________
Id say get the Ci5 + 460, gives him an option to go SLi later one depending on the board.
Discussion Starter #4
the board supports sli at dual x8 wich is really acceptable but the psu is 750w and i cant upgrade it if i want the total price to be in the price range he gave me... so upgrading to a sli 460gtx later would mean buy a new psu a 1000w...
Please only start one thread at a time on the same subject. I deleted the other 3 and left this one since it's your first.
a 750w really is enough for two 460s. dont follow psu calculators if its the one on newegg, it gives very fluffy recomendations. and if its a good psu even 750w might be overkill for two 460s.
GTX460 w/ 650-750w psu. Should be enough for you to SLI the GTX460's and overclock them.
1 - 8 of 8 Posts
