Smaller standard devian from the mean. It spends less time at 99% and less time at 1% so averages remain the same but frame pacing is more consistent providing improved consistency. Pretty much exactly what is observed by most people as smooth game play but doesn't show up well in metrics on charts.
EDIT: I do appreciate everyones input in online reviews, I'm not maliciously attacking jufus but...
I wish jufus would post SotTR 1080 lowest with SMT off as a measuring stick for comparison to determine the efficacy of his OCing. I doubt his x3d setup would crack 370fps.
It's another data point but, IMHO Jufus is, at best, mediocre when tuning Zen chips, advocating for static OCs as the best method, so his AMD CPU results should be viewed as the equivalent of low effort CPU OCing.
In his x3d vs AL video he was allegedly running at 4.7ghz on x3d but covered all info except latency on his Aida ram screenshot. 57.4 ns suggest loose timings for a 4.7 OC or massive clock stretching. 3800C14 for me, returns 56.2ns at 4610 all core speeds. 4112 C15 is 53.2ns. I mention this as, if this is his max tuned setup, it creates doubt as to his actual CPU OC efficacy. Notice he showed zero productivity tests as a result of his OC. R23 should have been 16k. You think he scores 16k....???
He claims cooling issues, but during gaming I never see my CPU over 42c CCD1. Add 20c to eliminate chiller and...62c, not exactly hot. Suggests he's brute forcing stability with too much voltage. I know from testing that is the wrong way to OC x3d and leads to stock level performance as FIT throws the brakes on hard.
Compared to a self proclaimed golden sample 12900k running max tuned DDR 5 7000+ with 32 CL and 4133 C15 on a different 12900k that has great DDR4 IMC.
