1 - 1 of 1 Posts
Hi been struggling to get the 580m in my M17Xr3 playing well with Ubuntu there is a bios bug that isnt going to get fix, due to this i thought i would see if flashing my 580m to a 675m would fix it and no luck. only problem now is i flashed back to my backup vbios and tried the throttle fix vbios and my card is showing up as a 570m with mismatched IDs when i flash the ID dosent seem to change back. Now i cant install drivers in windows, drivers still work in Ubuntu. just looking for any help.
shows as a 570m in Ubuntu, zgpu and in nvflash
NVIDIA Firmware Update Utility (Version 5.278.0)
Simplified Version For OEM Only
Checking for matches between display adapter(s) and image(s)...
Adapter: GeForce GTX 570M     (10DE,1210,1028,04BA) H:--:NRM S:00,B:01,PCI,D:00,F:00
WARNING: None of the firmware image compatible PCI Device ID's
match the PCI Device ID of the adapter.
Adapter PCI Device ID:        1210
Firmware image PCI Device ID: 1211
WARNING: Firmware image PCI Subsystem ID (10DE.0000)
  does not match adapter PCI Subsystem ID (1028.04BA).
ERROR: GPU mismatch
i have flashed with "nvflash -4 -5 -6 backup.rom" and it will flash but still shows as 570m
1 - 1 of 1 Posts
