5850 and voltages
1233 Views 14 Replies 7 Participants Last post by  rico2001
So this time around are the 5850s voltages unlockable unlike the 4000series 4850?
If so then how high is okay to run this 40nm at?
1 - 15 of 15 Posts
im running m 5850 BE at 900/1200 with 39c idle and 59c load.
But then again its a black edition card.
They are easily adjusted without any sort of mod or anything.
Just use MSI Afterburner.
Max voltage you should go safely is about 1.35v on air.
Try to keep it under that.
do you know what the stock voltage is? Or an estimate of it?
I think (this is from memory)
1.87v
POST 2200
I'm wondering this as well. And MSI Afterburner won't overclock past the 775/1125 limit for me. I would have to flash the bios.
Yeah, you need to put either the Asus or MSI bios on it.
will that cause any problems on a HIS card?
Or why not just use rivatuner?
Oh and are you sure its 1.87? I think that would kill the card.
1.087v is the stock 3D voltage of the 5850.
The stock 3D voltage of the 5870 is 1.15v.
I've killed two 5850s, one of which had 80 dollars of aftermarket cooling on it, with less than 1.3v.
You would think that after the first one you would learn.
Had to make sure, and I got my money back.
Anyway, now I know not to bother with the 5xxx line until someone starts making non-reference PCBs with real VRMs.
Wow are you serious? Your really scaring me there.
How in the world do you kill a 5850, it's over-voltage proof.
....unless there was a thermal problem, which is really hard to achieve.
How did I kill them? They are virtually the most delicate PC components I've ever encountered.
The VRMs cannot handle the power that can be drawn with even a modest overvolt/OC under heavy use.
First card was a Sapphire with stock cooling. I ran it at 900/1200 with 1.15v, it lasted three weeks then started to artifact in everything no matter the voltage or speed (even well below stock). Second card was an ASUS (which advertises overvolting/ocing right on the box). It got pretty warm past 1.15v so I replaced the cooling and dropped GPU temps 20C and VRM temps 10C. Ran that one at 1.25v, 950/1250, and it started to rapidly degrade after a week of use. When I sent it back it was not stable at stock clocks/volts.
Hmm, guess it depends on the owner.
1 - 15 of 15 Posts
