1 - 6 of 6 Posts
I really would like to get the most out of my 5850 and would just like some insight on how to go about OCing it, its on just the stock cooler. I have looked at some guides online but would really just like some insight as im not really sure the guides are 100% accurate. Im shooting for 775/1125 speeds if higher is still within the safe limit im all ears
Originally Posted by hardzy32;12032801
would that be safe to run or should i test it and if so how, very new to this. Thanks
first, use overdrive in CCC to OC to 775/1125, then download furmark to do stability testing. if you can run furmark for one hour without crashing or artifacts, then you're stable.
1 - 6 of 6 Posts
