1 - 15 of 15 Posts
Originally Posted by jy360;12999105
I want to know how to get past the 900mhz limit on the 1gb 5870, do I need to mod the bios or what? if so, please point me to the correct file
thank you
Originally Posted by kiwiasian;12999125
What "limit"....
900mhz limit in CCC?
Download MSI Afterburner Via
http://event.msi.com/vga/afterburner/download.htm
Once downloaded go into the Msi Afterburner CFG and change the EULA to I confirm... and overclocking mode to 1
* Set UnofficialOverclockingEULA field to the following text: I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
* Set UnofficialOverclockingMode to 1 to keep PowerPlay active (may not work on old ASICs), 2 to traditionally disable PowerPlay or to 0 to temporary disable unofficial overclocking path
They changed the way to bypass the limit so type this into your CFG file in Afterburner so you need to type in that sentence in the EULA to bypass the 900MHz limit
If you're referring to the CCC OC limit, that can easily be bypassed with third party overclocking applications.
Afterburner, Trixx, your pick.
EDIT:
Originally Posted by jy360;12999190
the one that stops msi afterburner going above 900mhz. I dodnt actually know if there is a set limit, I just know I can't pass 900 :s
Open the MSI Afterburner config file (MSIAfterburner.cfg) using Notepad (located in your Afterburner install folder), change the following string "UnofficialOverclockingMode=0" to:
UnofficialOverclockingMode=1
Then, enter the following as a statement confirming the limit bypass next to "UnofficialOverclockingEULA":
Originally Posted by kiwiasian;12999192
Go to the MSI Afterburner config file, change the following string "EnableUnofficialOverclocking=0" to:
This
· Banned
Originally Posted by kiwiasian;12999383
But can you unlock voltage control through the registry?
It's pointless to unlock higher clocks if you don't have access to vcore control
Pointless? If you can hit your clocks without mucking around in AB and Trixx, wouldn't that be the most efficient method? Not all cards need 1.3v to hit decent clocks.
EDIT:
When I try and save this, it says permission denied
How do I gain admin access?
1 - 15 of 15 Posts
