1 - 15 of 15 Posts
Hey there,
I just got my new Vapor-X 5870 rev.2 today.
Does somebody know what safe clocks are for it ?
I had Sapphire Vapor-X cards before (i.e. 4890Vapor-X) and they all lacked Volterra chips to enabled digital voltage tweaking. Only the Toxic models have that feature. So, I'm not surprised 5870 Vapor-X doesn't allow voltage tweaking. However, you can do a physical voltage mod to the card to unlock the voltages; it's possible; I've seen a tut somewhere... don't remember exactly where... maybe TechPowerUp.
Johnny
Originally Posted by Nick911 View Post
volts are fine to be at 1.25 and clocks can be as high as they can go. You got a great cooler already.
ATI HD5870's GPU voltage is 1.25V or 1.15V? I thought it was 1.15V.
Anyways, if the Vapor-X has 1.25V stock, then the card can reach the 975MHz/1300Mhz easy.
Johnny
Discussion Starter #11
Well so far I went to 900/1300 from 850/1250 and it runs fine.
Is it normal tho that the card runs most times on 400/1300 ?
Goes up to 900 sometimes like when I do something in my browser or play a game. But even when playing a non heavy ressource taking game it runs on 400/1300 sometimes. Surprises me a bit.
PC Evangelist
Very Normal. It should even drop lower but drivers are messed up. 2D clock should be 157Mhz/300Mhz which drops idle temps ~ 10C more. The only way to get those clocks is if you dont overclock or OC via Bios.
Melted Cheese
I have the same card as you do OP and I just went into overdrive and hit the sliders to the max (900/1300) and play all my games with no problem. Card keeps nice and cool with the Vapor-X cooler.
Also my card idles @ 400/1300 @ around 48C and I just couldn't care. The in game temps are great and the clocks really don't make any difference to normal operation so who cares. Oh, also the clocks stay up a bit if you have dual monitors (which I do).
Discussion Starter #15
Well it actually went down to 157/300 already before too.
But that was when it is was indeed not overclocked.
From what I saw till now the card runs awesome and very silent, compared to my two XFX 5770 XXX, which I'm selling now.
The fan only ran under 30% so far, which is pretty impressive, if you think about it that the card didn't even reached 45°C yet.
Gotta test several games tho to see how the card runs. Like by Assassins Creed 2 etc., cos with Allods Online the card won't be fully stressed of course.
Edit: I'm using the latest catalyst btw of course. 10.8. But I read 10.9 is out already.
1 - 15 of 15 Posts
