Hi,
i have been getting the amdkmdap error on my 5870 for around 8 months now but for some reason it has just became so much worse... the only way that i can actually play the game is if i underclock the card. so i am going to return it and get a replacement. Now i cannot decide if i should just keep the replacement or buy a Zotac 480gtx AMP Edition and sell the replacement 5870. now i dont care about the money so please dont say that its not worth all of the extra money, i am just worried about;
similar crashes (amdkmdap and stuff like that)
compatability
3d performance
overclockability
Now has anyone experienced crashed similar to the amdkmdap error with a 480? and is there a simple fix for it if there is one?
Is the card compatible with this rig:
Processor: AMD Phenom II x4 965 OC 3.7ghz
RAM: 4gb DDR3 Ripjaw
Case: HAF 922 (with 2x ethermax apolish 120mm side fans)
Cooling: Arctic Cooling Freezer Xtreme
Power Supply: Corsair TX850W
Motherboard: Asus Crosshair III Formula 790FX
Sound Card: SupremeFX X-FI
OS: Windows 7 64bit
will it be ok with my motherboard and will it fit in the case and is the PSU enough?
How is Nvidia 3d? i am just about to go read some review on it but i would like to know if it is any better/worse with the 480, i will be buying the Acer GD245HQ monitor is that a good choice with this card?
and finally, what kind of performance boost am i going to see over the 5870 when i OC the 480?
Any and all help will be greatly appreciated
compatability
3d performance
overclockability
OS: Windows 7 64bit
