1 - 20 of 30 Posts
for those of you that still play cs:s. Do you sometimes see it wigging out? when i get shot in my face my screen will flash white, has a few hiccups and glitches, just doesn't feel 100% smooth. Anyone else having any problems?
If I still had CS:S I would be able to tell you but alas I don't anymore. Is it at stock or overclocked(5970)?
I've been having problems with Source games in general. Other games work just fine.
Discussion Starter · #6 ·
i am still on the 10.3 betas i am not oc'd BFBC2 seems to run fine its just when i was playing cs last night. I did disable AI and last night i tried turning the AA up and that just made it seem a little more chokey so i had turned everything back down.
im asking to see if its a common problem or not before i start tweaking and trying to find a solution.
Discussion Starter · #11 ·
Originally Posted by firestormcomputers
Disable CF in the CCC, and see if that helps.
I have done that, i have to run it on 1 gpu, because if i get flashed my screen starts to wave when i come out of a flash ( thats with dual gpus running)
Originally Posted by Maris
did you bought 5970 to play css? *laughs*
LOL yeah, pretty hardcore purchase. Hope you intend on playing some new stuff like Battlefield Bad Company 2, Metro 2033, Mass Effect 2, etc!
PC Evangelist
Make sure you have Vsync off.
I play Diablo II and THPS3.
Originally Posted by Kye7 View Post
why are you the ONLY person that has 5970 problems?..
you should overclock
hes not the only person im having lil glitches on my screen as im playing, my FPS doesnt drop but the screen glitches here and there...
1 - 20 of 30 Posts
