5970 OCing
942 Views 19 Replies 10 Participants Last post by  ZealotKi11er
hi all.....
i have a quick power query regarding this card.??
this graph shows the power required in relation to the clock speed, now i only have a PCI-E 1.1 slot, so all in (1x 6pin = 75w)(1x 8pin = 150w)(PCI-E 1.1 = 75w) = 300w...
ok...so the question is when i go to OC the card b/c there's not enough power for it on the slot, could the card pull through more power from either the 6pin or the 8pin to compensate..??
my 850w PSU is heavy duty & currently im only drawing 175w idle & 301w load with the GTX260..... so there's plenty of play there..
1 - 20 of 20 Posts
I think you may have an issue overclocking the card, once you put the card under load. You will probably be limited on your overclock.
Don't even bother either bother with PCIE 1.1, Even a 5870 will be bottle necked there.
Does it really work that way? if thats true then i should have a problem because at stock my gts 250 pulls 175 watts at load and i have pci-e 1.1 and one 6 pin connector which means just 150 watts. And with an overclock it would be even more but i can overclock fine. Can someone confirm this.
You should really get a pci-e 2.0 board before you overclock that card.
@skunksmash
You can power the card but you wont overclock far. If you do get a 5970, I'd get a pci-e 2.0 mobo shortly after.
pci-e 1.0
75W (through pci-e slot) + 6pin plug (75W) + 8pin plug (150W) = 300W
pci-e 2.0
150W (through pci-e slot) + 6pin plug (75W) + 8pin plug (150W) = 375W
http://www.overclock.net/ati/613189-...ml#post7701568
How can you tell the card is actually pulling 175w? If you're looking at a kill-a-watt meter, or something similar, you're looking at how much wattage is being pulling from the wall. Efficiency is not accounted for, and going by your PSU, you don't list a brand so I'm assuming it's just a lower quality generic, which isn't very efficient.
Long story made short, your GTS 250 doesn't draw 175w.
my board is the next thing to be upgraded.... so im not too worried about its current shortcomings, i know it will run perfectly at the default 725/4000, so that'll do until my board is changed.
i was just wondering if it was possible to augment more power from one of the plugs..??
i guess what im asking is.....are the 6pin / 8pin plug voltages fixed..??, or will they give more if needed..??
another question too......
im gonna need a good CFX 775 mobo (with PCI-E 2.0) ??
http://www.techpowerup.com/reviews/A...xpress_Scaling
cheers pal.......
according to this, these new 5 series cards are actually designed for (8x PCI-E 2.0) = (16x PCI-E 1.1), so i should be fine...
look....there's hardly no difference between 16x & 8x ''2.0'' speeds..
Attachment 130088
the difference is minimal, but the results might differ from x2 cards because they likes the bandwidth.
The only qualm here is maximum wattage that can be supplied to the card which is 300w on a PCI-Express 1.0 slot limiting your maximum overclock. This honestly shouldn't matter too much to ya because the performance of a stock 5970 is quite stellar already.
furthermore.......
by the looks of it i can probably utilize the 4x secondary slot i have with a 5750/70 for ''Trifire''
, & keep my current board...
Originally Posted by skunksmash
cheers pal.......
Attachment 130088
Still that's one card and 5970 is much much more bandwidth hungry just like the 4870X2
yeah.....you could well be right....
, well i'll see how it goes, if bandwidth is bogged down too much i'll just run the 260 until i get a new board..
any suggestions on a CFX 775 PCI-E 2.0 board..???
Both 6 and 8 pin plugs can exceed 75W/150W respectively but it is not a lot and depends on how good your psu is. It's a amperage draw issue and better psu's can deliver more than rated.
cheers pal.......
Attachment 130088
The last 3 ATI generations have been designed for pci-e 2.0. Along with being right at the edge of powering the card with pci-e 1.1, you will be running the card at pci-e 8X, where your performance of the card will be reduces some 1 to 12%, depending on the game title.
furthermore.......
Do yourself a favor and get a pci-e 2.0 mobo since you are behind and will somewhat hinder most of the current cards. If you have $600-$700 to get a 5970, you should have $100-$150 fro a new mobo.
Radeon HD 5970 Overclocking Guide
cheers...
ok....so i need a mobo recommendation, its needs to be PCI-E 2.0 / CFX @ 8x or more / skt775..??
i cant afford an i7 setup yet, so i need to use the DDR2 & the 775 CPU..??
any ideas..???
Skunksmash,
I highly recommend either the Asus Maximus II Formula or the Asus Rampage Formula. I've owned those motherboards in the past and they are quite excellent. They overclock quite well and I have encountered no problems with them. They are rock solid and stable.
Try to get a X48 but if u want a single slot the a P45 and you will be golden. a Gigabyte U3DP is the best of all S775.
1 - 20 of 20 Posts
