1 - 19 of 19 Posts
Hi guys I want to buy a water block for my 5970 but I dont know which one should I get so i need your opinions please.
Also I only have 130 dollars to spend, so guys please any input in which one should I get for that money. Thanks
Super Moderator
Super Moderator
Edit; edit post next time instead of double posting.
I'm fairly sure most 5970s are reference, and that one sure is.
Discussion Starter #7
Ok thanks
Discussion Starter #9
Originally Posted by Stridarn View Post
I recommend you spend another 20 dollars on this one
Its the best one out there so you will never have to upgrade it.
I think I will get that one thanks man
Super Moderator
Edit; well, never mind, then. But if you're going to spend extra, get the nickel-plated version there as it's not subject to oxidation like plain copper is.
Originally Posted by KILLER_K View Post
http://www.sidewindercomputers.com/ekwaekac2.html
Like this one a bit better then the heatkiller as it cools the vrms a bit better.
I would have suggested that if his budget wasn't $130. :/
Discussion Starter #12
I heard that some 5970 has something call coldbug, is that true?
Never heard of it tho..
yup EK hands down....good advice man
I read that in a forum but I dont remember in which one :/
Im not sure but i think all the ati card can suffer from coldbug.
Coldbug happends when you install an aftermarket gpu cooler onto the gpu. But it will work if you install the stock cooler again onto it.
(if youre unlucky)
1+ rep please
Well, hello there...
EK Nickel FTW!
Discussion Starter #19
(if youre unlucky)
1+ rep please
Hey thanks, But what exactly is that? Because i dont want to break my card
and yes you got rep +
1 - 19 of 19 Posts
