Erm... The 4 SSDs seem like overkill a bit, but will definitely give you a significant boost over the 2 x 1TB.
Not sure about whether or not you're going to need a better controller, but if you're going to pour 400+ bucks into a setup like that I would just to be safe. IIRC, the maximum most onboard controllers can handle in an array is 4, although I am a bit outdated, and may be wrong.
Don't really see the point in running all 6 drives in RAID0 though.
