Originally Posted by YiffyGriffy That's a little warm, mid 50's is normal, keep it under 70-75 for load is what I'd say. |
Originally Posted by adas123 yeah, those are pretty normal temps...just put more ventilation by it and u can oc way more |
Originally Posted by Waffles i have a fan blowin on it from side panel and 2 pci slots directly under it opened. how could i get more ventilation than that? |
Originally Posted by Evil XP2400 If you have some AS5 laying around you could remove the heatsink, wipe that crap off, apply AS5 and that should help your load temps quite a bit. |
Originally Posted by ItsLasher Two fans right next to each other will cancel each other out as far as air flow ........they are fighting each other...........try to place a card(i.e. sound,ethernet) bewteen the fans to allow more flow Edit: I thought you had 2 pci fans ...my bad |
