64 or 32
249 Views 4 Replies 5 Participants Last post by  tpavur
do you have to have 64 bit os to run sli?
1 - 5 of 5 Posts
SLI does works with 32-bit. But don't forget the whole issue of only being able to address 4GB of memory (system & video)
64-bit is the way of the future
It works with 32 bit as well.
32 or 64 does not matter.
either one but i do not believe 32 supports tri channel ram. not that the two are related, just food for thought... there is alot more pro's than con's when using 64 bit OS
1 - 5 of 5 Posts
