1 - 4 of 4 Posts
so i downloaded tcpmp for my 650 but all it does is lagggggg. i can whatch about 4 secs then it goes for 2 secs loading. i'm using mpeg. has anyone else had this problem? well i'll try it on my 600 and maybe i'll overclock it a bit for a little boost
Do you have any apps running in the background when viewing a movie? Also have you converted the video properly for the Treo? I use TCPMP for my PPC-6700 and find it great. See if you can use a software called Pocket Divx to convert them for TCPMP.<br />
<br />
pink
did yoiu resize it at all ? the video that is
perhaps your pda isn't powerful enough? my old 520 Mhz FSC 720 still couldn't play some small vids!
1 - 4 of 4 Posts
