NO DONT GET THOSE
GET THE 71.20B'S THEY ARE WAY BETTER HERE THEY ARE DONT GET THESE http://downloads.guru3d.com/download.php?det=948 to install well u know download then a self unzip utility comes up. highlight anything that it says under it and then copy. then click extract. after that go to run right click paste. then something will pop up saying vgx. something or guru3d.com click on whatever one is there and you will see something that says setup with 3 triangles connecting like a chain. once u do that it will install! GOOD LUCK also it comes with coolbits3d overclocking utility built in
the geforce version of the 71.20 from vlance studios is like a modified 71.20 so geforce works for it not rly that many optimizations. the 71.20b is optimized for 6series users (nv4x) not (nv3x) wich is used by geforce cards 5200-5950
no the 71.20 (Geforce FX) is a plain 71.20 with a few optimizations cuz they havent came out with a second 71.20 for geforce series just one cuz thats the only one for it. and the 71.20b's are called b's cuz they already came out with one for 6 series not 5 series
