1 - 15 of 15 Posts
hi guys have a problem wondering if anyone could help please?
all other games loaded on hdd such as call of duty 2 doom 3 zero hour all play fine no problems,but when starting up sims 2 there are a lot of white lines all over the screen same on my other lads machine,but on mine it works fine i have an fx5700 agp.
any help would be great
What card manufacturer are you using? My eVGA card came with a disk with old drivers on it. If you used your disk, you might have problems. My card artifacted like hell when I used the included drivers. As soon as I dowloaded the latest ones off of nVidia, I was fine.
i have installed the 81.98 drivers from nvidia still the same problem
Maybe Sims doesn't like your card. I don't play it, so I can't be of further help.
Discussion Starter #9
as i said i have an fx5700 and it plays just fine on mine.
oh also i have NOT overclocked this 6600le card at all
Try to rma the card. there might be a hardware problem.
Discussion Starter #11
rma?
i am about to put the fx5700 card in his machine and try that and put the 6600le in mine and see if it is the card,should'nt be though its only 3 days old both of them
Discussion Starter #12
yep just as i thought i think the card has had it,tried to play different games and theres just blocking everywhere.
only problem is i bought it off a ebayer so i will have to get in contact with him and either try to get my money back or sort off the warranty
yea.. RMA (Return Merchandise Authorization) it, if you have a serial number on it, and its not more than 3 years old (usually) you should be able to get it replaced without even having to go through the guy you bought it from. What brand is it? eVGA, XFX, BFG, etc?
Discussion Starter #14
it's an xpertvision.
thats what is writen on top of the fan.
so just a quick question what ,where and who do i contact now to get it replaced?if you know this of course,and yes it does have a serial number on it
1 - 15 of 15 Posts
