Does anyone have a custom bios for a EVGA GTX 660ti SC?
Thanks guys!
Thanks guys!
Thanks , Ill check this out in a little bit.Originally Posted by hammong
There are ways to do this, but I wouldn't attempt it without a decent water cooling loop on the card. Your temperatures could easily get out of hand and leave you with a dead GPU.
Here's a thread for your consideration:
http://www.evga.com/forums/tm.aspx?m=1770296&mpage=1&print=true
Have you tried jacking your fan speed up? If you can keep your core at a lower temp, it might not throttle as bad.
Greg
