Hey everyone.
I currently own a 670 4GB GPU. I want to upgrade my system in the upcoming weeks.
I know that 670 4GB will give me more fps in games, but Titan has its uses as well
670 4GB SLI
+ More Fps
+ Budget friendly
Titan
+ Less Power Consumtpion
+ Less Noise
+ Less Heat
+ No possible SLI issues.
Now it seems that a Titan can be OCed well and might be as close to a 670 SLI setup or perhaps on par. So that is something to think about.
If you were currently in my shoes, which road would you go?
670 4GB SLI?
Titan?
or wait for thje 7xx series (which is not clear when they will arrive, also I dont believe 780 will be as powerful as the Titan)
Thanks in advance
670 4GB SLI
+ More Fps
+ Budget friendly
Titan
+ Less Noise
+ Less Heat
670 4GB SLI?
Titan?
Thanks in advance
