1 - 13 of 13 Posts
well......basically....x800 gto is better than the x1600xt in pure power BUT will not support h264 decoding or SM3 or HDR. 6800GS i know is mor epowerful than gto. but as said you can might as well wait for an 7800GS. they support latest technology and powerful
the 7800's are out... no waiting!
man if i were you i would get the evga 6800gs i just got it yesterday..you should read my thoughts on it lol..its phenomenal!!you reely should get it...heres the link if you want to check it out..its a great overclocker, and it handles the new games at highest settings!!
unless you're planning on getting an x800gto2 and unlocking it then its probably a better idea to get a 6800gs. infact even if you're planning on unlocking/overclocking it, its probably a better idea to get the 6800gs anyways.
The 6800gs has better shaders...go with it, or even better the 7800gs.
i would say gs but my budget was ultimately 120 pounds and that was a gto....6800gs at that time was 180 pounds. iw ould reccomend 6800gs but see benchamrks if spenidng extra 60 pounds is worth the extra performace you get in a 7800gs
1 - 13 of 13 Posts
