awesome lol
nasty in there aye? do you know were i should post faqs? oh and also this should make your oc's easier
i check every month but i do a bit more screw work to do it more effectivly than a can of compressed air.... i dont know about other models of graphics cards but... i know that alot of heatsinks are flawwed and have alot of dust build up over time hidden
. yes it dropped my temps exactly the same actually to 38c
and i can overclock to 405/1.13 easily but i would suggest just doing 370/1.05 and 380/1.05 for 3d it wont hurt ur card at all and it will help you out with like 1-3 fps
might just knock of that little studder here and there to. especially how much lower it dropped..
30c down big drop wewt!!!!! oh yeah and when u blow into the fan it makes it worse.. lol it only gets rid of the little specs but pushes the dust farther into the gpu and if you have a clear heat sink.. well your lucky because once you open your case you will eventually see it lol
