Current setup:
Windows 7
6870 MSI, Twin Fozzier II, RMAed to Twin Frozzier III
ASUS Motherboard M4A88TD EVO
Phenom 955
Issue:
Everything was working great the past two years, I have two monitors, a DVI and a VGA. I have the VGA hooked up to the top port, using a DVI adapter, the DVI has always been plugged into the bottom port.
I work from home and plugged my DVI monitor to my docking station so I could dual display my work laptop.
After I was done I went back to my desktop I plugged it back and rebooted. I am not sure what happened but the PC will no longer display anything with both monitors plugged in anymore.
Here is what I know,
*when I have both the monitors plugged in the PC will boot, IE I hear the Windows load chime
*Same thing happens if I have only the DVI monitor plugged in the bottom port
*When I have the vga plugged in the top port only everything works
The DVI monitor works, I have verified this, also when I have it plugged in the bottom port I am getting a signal sent to it, as the screen will switch from no signal received more to a blank screen as soon as I power up the desktop. Also after the PC boots I can unplug the cord from the cards bottom slot and plug it into the top one and the Windows screen looks fine.
I RMAed the first one thinking the bottom port went out, the new is doing the same thing. I also updated my BIOS to the lastest version and this did not do anything to resolve the issue.
Any help or suggestions would be much appreciated
Cheers
…Hide content ?
Windows 7
Phenom 955
Issue:
Cheers
…Hide content ?
