1 - 9 of 9 Posts
Discussion starter · #1 ·
Will the ATI Sapphire 6950 fit in the HAF 922? It's 10.5" long. If it doesn't fit, what case would you recommend? Also, I plan to crossfire in the future. Thank you for the help.
short answer...yes. the Haf 922 can fit any card out right now....not 100% about the 5970, but i think that would fit, but the 6950 is atleast an inch or two shorter than that. i have one sitting next to me, seems plenty big.
Yes 922 can fit it no problem. Last i checked even HD 5970 can fit no problem.
Discussion starter · #7 ·
Thank you guys. I just ordered the 6950 & HAF 922 limited edition case, and I wasn't entirely sure whether it would fit. Again, thank you.
Eros, are you going to unlockthe beasts true power?
1 - 9 of 9 Posts
