1 - 5 of 5 Posts
is this score is good with this setting?
Processor
Intel Core i7 970
Processor clock
3990 MHz
Physical / logical processors
1 / 12
# of cores
6
Graphics Card
Graphics Card
AMD Radeon HD 6970
# of cards
SLI / CrossFire
On
Memory
3 MB
Core clock
0 MHz
Memory clock
0 MHz
Driver name
AMD Radeon HD 6900 Series
Driver version
8.801.0.0
Driver status
Not FM Approved
General
Operating system
64-bit Windows 7 (6.1.7600)
EVGA EVGA X58 Classified 4-Way SLI
Hard drive model
Memory
12288 MB
Module 1
2048 MB G.Skill 9 @ 667 MHz
Module 2
Module 3
Module 4
Module 5
Module 6
Detailed scores
3DMark Score
P9063
Graphics score
9281
Physics Score
10135
Combined Score
6791
GraphicsTest1
42.0 FPS
GraphicsTest2
49.06 FPS
GraphicsTest3
59.76 FPS
GraphicsTest4
26.18 FPS
PhysicsTest
32.18 FPS
CombinedTest
31.59 FPS
Settings
Default settings used
Yes
Edition
Basic
Screen Width
1280
Screen Height
720
Msaa Sample Count
1
Texture Filtering Mode
Trilinear
Max Af Anisotropy
1
Tessellation Detail
5
Max Tessellation Factor
10
ShadowMapSize
5
Shadow Cascade Count
Surface Shadow Sample Count
16
Volumetric Illumination Quality
5
Ambient Occlusion Quality
5
Depth Of Field Quality
5
Enable Window Mode
Off
Enable Vertical Sync
Off
Enable Triple Buffering
Off
Enable Wireframe
Off
Color Saturation
100%
Your score is P9063. That's about right.
I get P9424 with my 6950CF, they are flashed to 6970+OC
Programmer
You should be getting 10k. Try 11.4 drivers. At the end of the day, if your games play perfectly fine, there is no need to worry.
1 - 5 of 5 Posts
