Please post shots. Post something you can buy, something you've installed, or what you've made yourself. Pls make the photos links to the shops where you found them if you can buy them, or post your own shots with air cooling already installed and tell us what you did.
I am considering custom rigging bigger fans if possible. 80mm fans might not fit, but they probably come close. So there has to be something in the 65-75mm range that would be the perfect fit to max air flow for hot rooms and high OC's. Mounting them might require some creativity, but there's gotta be an easy way. And keep in mind you could buy two more fans and chop them up for perfect shrouds.
I would love to have at it. I don't care it if is ugly, just want it to be quiet and well directed high-CMF.
Here are some 2 x 60mm fan systems you can buy:
And a 70mm x 15mm fan which I guess should fit in pairs over 6 DIMMs:
And here is a quieter 70mm x 10mm. Also could scrap two for shrouds:
