1 - 9 of 9 Posts
Originally Posted by Azule
God. they are all good what should i be best with? [preformance]
I like the 71.20's but just try each one and run some benchmarks. Every system is different so try em all and see which one works best for you.
The 71.80 forceware is tops. the ones your useing is Quality have you noticed? I uninstalled the 71.20c and it sayed V studios Quality. So i guess i have met my drivers
Im useing the GeForce Tweak Utility with help file.. it helps alot.
the 71.20's locked my system up....71.80's worked great....DNA 1.71.80's work better for me....about 4-5 more fps in doom 3
Nice
71.80s crshed my system so I went back to 71.25s which do me better than the XVG sets... I like th XVG but I wont use the 71.20c since its based for the FX series of cards NV3... If I went back to XVG it would be the 71.20b set.
EDIT: Sorry it was the 71.81s that crashed my system. Not the 71.80s.
Discussion Starter · #9 ·
EDIT: Sorry it was the 71.81s that crashed my system. Not the 71.80s.[/QUOTE
They crashed me playing Doom 3. Im useing the 70.20c
1 - 9 of 9 Posts
