As some know by now, my show BMW 518i has been stolen recently. So now I bought a 1970 VW 411L Automatic, with the intention of restoring it to show condition.
Details:
Things to do (the list will be updated as needed):
I'll try to post some pictures today.
Details:
- 3 Speed auto gearbox, sometimes won't go from neutral to drive, but always goes from 2nd to drive
- 1679cc (?) flat-4 engine, aircooled, single Weber carb. According to papers I found in the car, the engine's been replaced in '85. - Might be a 2.0 that's been upsized to 2.3, the roadworthy certificate states 2300cc and 64kW
- Light blue paint, same as the BMW, and lots of overspray.
- Rust repair behind FL wheel
- Remove overspray, respray FR fender due to bubbling paint
- Cover dash with synthetic leather - Got a quote, but I don't want to pull the dash out at the moment.
- Repair seats, if possible with original upholstery - Looking for the original design.
- Fix speedometer - Cable snapped inside the speedometer, so I need to get the tip out before a new cable can go in. Will be using a GPS in the meantime.
- Install custom killswitch(es), to prevent another theft
- Fix poorly panelbeated RL door - Not perfecct, but as close as it'll get without putty
- Replace blown lights, and fix wiring where needed (almost done)
- Fix vaccuum leaks - Done again, hopefullly the last time
- Suspension work - I'll have to replace the shocks, but I've been told that they're discontinued
- Adjust/replace the gear lever cable - Gears don't align with the lever positions
- Diagnose and fix intermittant dead cylinder, and what appeared to be a sticking valve (backfire through carb, might be related)
- Minor accident repair - Scratches are buffed out, and the beading is back on, so only the dent remains.
- Replace snapped throttle cable - Currently ghetto-rigged with a piece of binding wire and a clamp
2016-11-5: Initial service, some other stuff
2016-11-22: First vacuum leak
2016-12-12: Started to salvage the horrible paint
2016-12-17: More pictures of how the paint came out
2012-12-31: Second vacuum leak
2017-3-13: Exhaust manifold gaskets, custom silencer, third vacuum leak, painted engine parts
2017-3-24: Brakes failed, fourth vacuum leak (botched assembly and calibration during previous engine work)
2017-4-14: Electrical issues, preparing for next show
2017-4-20: Painting the exhaust
2017-5-25: Painted the horn and wiper arms
2017-6-29: Paintless dent removal on door
