1 - 20 of 26 Posts
Hey guys, like the title reads I'm doing a build for a friend and his budget is $700. He would like to do intel and invidia hardware. He does not need an i7 but an i5 is desirable. He will never overclock or use SLI. He would only need 500GB or less of HDD space. He already has the monitor, mouse, keyboard and speakers. So we just need the tower.
I was looking at micro ITX builds but I'm not sure what motherboards/cases are good in those areas. I was also looking at a GTX 460/550 ti. Advice?
Edit:
CPU:
http://www.newegg.com/Product/Produc...82E16819115220
Motherboard:
http://www.newegg.com/Product/Produc...82E16813128457
GPU:
http://www.newegg.com/Product/Produc...-625-_-Product
Now looking at PSUs and RAM.
Originally Posted by davista111
Does he want a small, M ATX pc or a full blown tower? Also will he want to play a couple games?
He doesn't need a full tower because he will have only one graphics card and one hard drive. He plays Starcraft 2 and Left for Dead 2, so that's why I'm recommending the GTX 460 or 550 ti.
I did a build like this. I used an i3 but you could probably use an i5 my budget was lower the rest. But I used an Asus p7p55 lx mobo, 4 gb of corsair vengeance ram, evga gtx 460, samsung f3 500gb, thermaltake 450w psu, hyper 212+ cooler all in a haf 912.
Of course that was an atx build but you can easily find a smaller case and a comparably matx board.
R5 3600 / X570 Aorus Elite WIFI / EVGA RTX 3080 Ti FTW3
Edit:
CPU:
Motherboard:
GPU:
I hate to bring it up, but you could go AMD. Get a AMD x4 or x6 and get a better GPU (a 580 or 6970). Just my two cents.
Going AMD is definitely an option here, since your budget is only $700. You might want to make a thread in the AMD section though, I'm not sure how many of us in the Intel section actually know sufficient info for AMD (I do not, which is why I point this out).
Im not really sure why you want to spend $200 on a dual core processor instead of buying your friend the nicest 4 core gaming cpu for the same amount of money. Just pay a bit more for a motherboard. I would really reconsider on getting a psu with just enough power for 1 gpu. He could change his mind latter on about getting a second card. Its always nice to have a little room for upgrades.
Discussion Starter · #17 ·
Originally Posted by Invisible;13037193
You could pay like $5 more and get a GTX460. Just overall better than a 550.
You could also spend $3 more and a get 1TB Spinpoint F3.
Why would you prefer the GTX 460?
Good catch! I didn't know i5's came in the dual core variety. How about this one? http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067
Haha, I didn't even notice that was a dual core.
On-topic, let me build you two builds. One AMD, one Intel, and see if you like this. Will either edit post or make another post with these.
1 - 20 of 26 Posts
