1 - 9 of 9 Posts
So I got the following pieces in mind for my brothers build:
Mobo - http://www.newegg.com/Product/Produc...82E16813128381
GPU - http://www.newegg.com/Product/Produc...82E16814161260
PSU - http://www.newegg.com/Product/Produc...82E16817139005
CPU - http://www.newegg.com/Product/Produc...82E16819103472
RAM - http://www.newegg.com/Product/Produc...82E16820231209
HDD - http://www.newegg.com/Product/Produc...82E16822148335
CD/DVD Burner - http://www.newegg.com/Product/Produc...82E16827106287
CPU Cooler - http://www.newegg.com/Product/Produc...82E16835233029
If you can make a better build for cheaper, or suggest another part instead of the ones above then it will be greatly appreciate and reps will be shared. I want it to be $700 or LESS. My brother have a strict budget of no more than that. Also, I already got him a Antec 300 case so dont worry about that.
Thank You.
Efficiencycionado
the powersupply is just too pricey for such budget build. plus it's an overkill for that setup. a niec brand with 550w is more than enough, even with crossfire for that card or even a 4850.
http://cmstore.coolermaster-usa.com/...roducts_id=104
then add more budget for a videocard:
http://www.newegg.com/Product/Produc...82E16814161268
and if you can wait, the 4850/4870's price will drop down to $130/150 anytime soon.
oh yeah, i'd get the powercolor instead of the his (if it's not the iceq) since it's more overclockable and is better at stock:
http://www.hardwarezone.com/articles...724&cid=3&pg=4
Reactions: Labombadog
Why don't you get an AMD Phenom x3 720 instead? The 4th core on it can be unlocked on most 790gx motherboards plus you'll save yourself a few.
Also for motherboards look into the Newegg Open-Box items, i'm sure you can get a 790GX for around 70.
4830 is a 110w GPU and 4870 is a 150w GPU. A soild psu can do 470w should be fine. Since 650tx is the same price as 550vx so get the 650tx. gerikoh has good suggestion. The real power pro is a good series in CM. If they come with warranty so it should be fine.
Discussion Starter · #6 ·
Are all Phenom x3 720 guaranteed to have a 4th core unlocked?
Also, thanks for the help. I have repped everybody so far!
Efficiencycionado
nope. just a few selected batch 0908 (or something like that) paired with a few selected 790gx mobos.
Since it's an AMD system, you don't need to get the Dark Knight, the regular S1283 would be just as good. Intel people get the DK for the bolt through mounting system. As I understand, you can't use it on AMD.
1 - 9 of 9 Posts
