1 - 4 of 4 Posts
which one is better and buy how much also if worth the price<br><br>
1. EVGA E-GEFORCE 7300 GS 550MHZ 128MB 650MHZ DDR2 PCI-E VGA DVI-I TV Out Video Card for $62.62<br><br>
2. x550 256mb at 400mhz the one i own now<br><br>
3. Geforce 6600GT 256MB PCIE for $125.00<br><br>
4. PowerColor X800 GTO Technology Specifications for $139<br>
‧ 12 parallel pixel pipelines<br>
‧ 6 parallel vertex processing engines<br>
‧ 160 million transistors on 0.11 micron fabrication process<br>
‧ 256-bit quad-channel GDDR3 memory interface<br>
‧ MCE support<br><br>
5. ATI Radeon X1600 Pro 256MB for $139.00<br><br>
6. ATI Radeon X1300 256MB for $85.00<br><br>
7. XFX GeForce 6800 Xtreme 350MHZ 256MB 256BIT 1000MHZ GDDR3 AGP Dual DVI TV Out Video Card for $145.82
6800 xtreme, it has the chance to be unlocked to 12/5 and overclocks pretty well. The 800gto might be a tad more powerfull, but it lacks smart shader 3.0 . the 6800xt is a bit newer tech and would benifit you more in new games.<br><br><br><br>
Burnstudios
The X800GTO and X1600Pro would be around equal, with the X800GTO being faster in games but lacking SM3 support<br><br>
the X1650Pro, while not on your list, is a great buy:<br><a href="http://www.ncix.com/products/index.php?sku=20905&vpn=H165PRQT256GDD-R&manufacture=HIS" target="_blank">http://www.ncix.com/products/index.p...anufacture=HIS</a><br>
the one above is faster... by alot<br><a href="http://www.ncix.com/products/index.php?sku=20643&vpn=11090-01-20R&manufacture=SAPPHIRE" target="_blank">http://www.ncix.com/products/index.p...cture=SAPPHIRE</a><br><br>
the rest of the ones in your list I wouldn't consider<br><br>
edit:<br>
I worry that you do not know the difference between AGP and PCI-e<br><br>
they are separate slots, and different technologies. <i>A PCIe card cannot be used in an AGp slot and vice-versa</i><br>
your motherboard supports PCIe only,<br>
you cannot use the card burnstudios suggested
<a href="http://www.ncix.com/products/index.php?sku=20801&vpn=256-P2-N615-TX&manufacture=eVGA" target="_blank">http://www.ncix.com/products/index.p...nufacture=eVGA</a><br><br>
There should be some deals on soon; if you wait a day or two, that card might come on sale. It was only $135 yesterday, and it creams every card listed.
1 - 4 of 4 Posts
