1 - 5 of 5 Posts
I have 2 bfg 7600gts in SLI. Here is my problem. Everytime I overclock, i get very high and stable clocks with ATI Tool but then when i try to run 3dmark06, my comp hangs and reboots. Is this normal? 3d mark will only run at stock settings. Keep in mind these are volt modded cards but they did this before modding too. Should i just try to return them or sell them?
If they are defective, I would not sell them with a clear conscience. Maybe try to return them for an RMA? I don't know what BFG's RMA policy is, but if it is like EVGA, then OCing does not void the warranty.<br />
<br />
Perhaps your PSU - SLI usually calls for 550-600W..?
Bfg overclocks their cards from the factory, so you might not be able to oc them all that far. Does it hang when they are at the stock clocks?
Check temps. I have a similar issue with my BFG 7600GT, it will overclock or so it says really nicely, but then I get lag in games and a restart. Dunno.
same here<br />
<br />
i had mine srable @ 750 - 850 but i started to get lagg<br />
<br />
not they are only running 725 - 850 but i guess thats still good
1 - 5 of 5 Posts
