1 - 1 of 1 Posts
I had some question's to see if you could help me out on where to mount my XSPC 270 D5 Pump/Res Combo on my Corsair 760T.
The plan is to rotate the CPU block so the inlet and outlet are stacked top to bottom. Keeping that 90 going to the top 360 Rad.
I'm thinking of mounting it in between the grommet for the Motherboard cabling.
I did get a 90 degree adapter then plan to use another 90 so I can run the tubing along top rad through the drive bay and connecting it to the front 240 rad.
Thanks in Advanced
1 - 1 of 1 Posts
