Hello.
Well, sorry to break it to you, but the 780i isn't really renowned as a good overclocker, especially for Quad Cores. However, there is a guide that you could read that may help you out a bit.
http://www.overclock.net/intel-mothe...ing-guide.html
That should help slightly, but other than that I can't offer much assistance. Other than increasing the core voltage and PLL Voltage, as well as giving it plenty of NB volts. The 7*0i boards love NB voltage.
I just wish I could remember more about overclocking on an nVidia chipset... I've not been there in a while.
Have fun, and good luck! Be sure to post the results here.
PS. About the difference in core temperatures: it could be due to an unflat CPU, or an unflat CPU block (not likely) or just a bad mount. Intel's CPUs generally aren't very flat, so you may want to check that if you ever do a re-mount. You've got nothing to worry about though. I'm assuming your temps stay in line.
Edit: Be sure to do the Pencil mod on there. NForce chipsets generally have awful VDroop, and the pencil mod pretty much eliminates this, or it did for my P5N-D.
Oh, by the way; you might want to think about cooling your north bridge more actively, whether it's in your WC loop, or whether you just buy a fan for it, it's a good idea; the NF200 chipset gets ridiculously hot.
