1 - 7 of 7 Posts
Alright i have a problem. I have a XFX 7900GT OC 550mhz/1.6ghz (stock from factory). Now i want to SLI but the problem is they don't make my card any more (PV-TG17-UDP7)
I've checked like every website, checked ebay but nothing. So i phoned up XFX and started complaining....and they said that i could use ANY card aslong as the GPU (7900 GT) and the ram (256) is the same. O.k that made my feel better. I goto the store to buy an MSI 7900 GT and the guy is like it won't work that good because both the cards are different?! Different chips components/software etc....not a good idea. Ohhh o.k. So i've also tracked down another XFX card that runs as 520 OC (can't OC any more) but not sure if that's a good idea since one card is at 520 and another is at 550. So my question is:
1) Can i run 2 different cards as long as the gpu is the same or will i have problems?
2) Should i get the 520 OC edition from XFX?
3) Any other suggestions on what i can do? (besides sell my card).
You installed?It work in SLI?Go and try.Nothing going to happen if don't work.
Two different manufacturer cards will work in SLI as long as they are the same core e.g 7900GT & 7900GT, 7900GS & 7900GS........no pick & mix
both cards will definately work together. both cards will operate at the slower speeds of the two.
although... why SLI 2 7900GT's at this point? sell one for $200 and use the $300ish from the 2nd to buy a 8800GTS
Discussion Starter #7
Would 2 SLI 7900's gt's running at 550mhz/1.6ghz run faster than one 8800? Or would the 8800 outperform both of them?
1 - 7 of 7 Posts
