Hi,
As far as overclocking goes i have relatively little knowledge. I basically want to know if it's possible to overclock this card in Vista RTM? Or will i need to bios mod it using XP and then boot into Vista?
Also, on XP, i got pretty good OC'in results using coolbits however when i OC'ed my CPU from 2.13 to 2.72 and tried getting the same results using coolbits, i got artifacts after only a few mhz of OC'in. Why is that?
Thanks, Law
Specs:
Core2Duo E6400 CPU
XFX 7900GS GPU
ASUS P5B mobo
1.5GB DDR2-667 Budget Ram
CPU&GPU Astek Waterchill Watercooling
Thanks, Law
Specs:
Core2Duo E6400 CPU
XFX 7900GS GPU
ASUS P5B mobo
