1 - 6 of 6 Posts
Would be great if some of you shared your results, what card you use, and your clocks!
Which programs do you use to benchmark
What settings do you test on when using Unigine?
First test I've done so far, I tested it the way program was set up by default!
Old to Overclock.net
You first need to set you Nvidia Control Center (or whatever it's called
) to default.
Then you need to run at Extreme HD settings (choose the preset box and it should give you this option), then join this thread here:
Top 30 --- Unigine 'Valley' Benchmark 1.0
You can compare your results to the different cards there and even try to beat a few of them along the way!
For reference here's my score at the settings i mentioned:
mark_thaddeus --- [email protected] 4.7Ghz ---- Sapphire 7950 OC Edition ; 1268 Core / (1861) 7444 Memory ----52.0 AVG. FPS ----2176 Score
A couple of benchmark to use as well are:
1. Heaven 4.0 - We also have a club just like the previous one with a ranking system if you want to get into that.
2. 3dMark - The new one with Fire Strike in it
These two are more representative of a stable OC verus the Valley 1.0 which is just balls to the walls OC type run.
Originally Posted by MegaHertz View Post
thanks for all the info mark
Nvidia control panel?
i don't think ati cards have one of these
Sorry, I was focusing too much on your sig rig not being there when I should have just looked at your screenie saying 7900 series. In that case set CCC to default under "gaming" and you should be good to go!
1 - 6 of 6 Posts
