1 - 4 of 4 Posts
Hey guys! I'm going to be starting 800d watercooling system and have a few questions about rad/fans/airflow.
So I have a rx 360 mounted top and a rx 240 mounted on the bottom ( had to cut it with dremel, but came out descent). How should my air flow be?
I'm thinking fans mounted on the top of the 360, pulling out of the case and fans mounted top of the rx 240 pulling also, and pulling air from outside to inside of the case?
Is that right? Any suggestions?
Storage Nut
If you have teh fans sucking in air into the case you may see better temps. I know when I did it that way it dropped my temps 3C.
Originally Posted by Juggalo23451
My friend and I did the same. I think he has his fans in push/top. Pull at the bottom. Sucking the air up. He got better fans for the case. Does your setup look like this?
Yes thats how it is. Are you using push/pull for your 360?
1 - 4 of 4 Posts
