1 - 5 of 5 Posts
I have a stock 800D, my thermal intake aio finally crapped out.. i want to upgrade cooling/fans
The cooler i think is best is the h100 v2
Can someone post a diagram of fan location and some good fans? There is a few on google images not sure what's best..
here are complete specs.
I picked a AIO cause i never had luck with any air coolers maybe that can change..
here is my complete specs
Computer Specifications
Case:
800d
Motherboard:
ASRock Z77 Extreme4
CPU:
3770k intel quad core OC'D 4.2 g
Memory:
G.SKILL Sniper 8GB (2 x 4GB) 240
Hard Drive:
samsung 840 ssd
Video Card:
670 overclocked
here is a little diagram i found not sure if it's the best or not
what do you mean not much luck?
AIR coolers will be cheaper and tend to be quieter (depending on fan) while AIO's have better all out cooling. I prefer water over air and due to my case size the larger air coolers won't fit (not that I want 1kg of metal hanging off my mobo).
what is your budget?
I wouldn't mind spending 100$ on a cooler, but i also want to put few fans in as well. to make cooling the best i can.. right now when i game i hit 77-80C which is too hot for my liking.. my 5 year old AIO isn't pumping good or is out of water.. (cant refill?)
Discussion Starter #5
loosing 10C won't improve performance unless you want to OC more. If you like AIO's buy a new one.
10C does make a big difference, as i notice it in FPS once the CPU get's warm..
I dont mind the AIO im just looking to upgrade the AIO and try to get better fans/airflow
1 - 5 of 5 Posts
