Hey guys,
So I'm pursuing to get into the 5GHz club with my 8320.
Now I know my Motherboard ( 970a-ud3) cant handle too much pressure before throttling. It does this after 10 seconds of Intel burn -.-
So knowing this, I thought id go ahead with the run to 5Ghz for a one time thing.
4.7 was fine, throttling like hell but still fine.
I went ahead with 4.9 being impatient. I upped the volts to 1.46 as by looking at the 5Ghz club, in order to get there, you need 1.5+ volts.
So after a re-boot, I open up CPU-Z and it read 4.9ghz with 1.46 volts. But then when HWINFO64 opened, it only said that cores 0&1 was at 4.9 and the rest was at 1.4?
So my question would be how do i fix this?
Do i add more volts to allow the other cores to get to 4.9?
Or can my board/PSU not deliver the right amount of volts?
Build:
AMD 8320
MOBO: Gigabyte 970a-ud3
PSU: Corsair CX 500M
RAM: Kingston Hyper X 8GB @ 1600
http://s1314.photobucket.com/user/Editiionz/media/832049problems_zps96856fa3.png.html
Thanks in advance for all the help & reading this
Build:
AMD 8320
