8600gt GPUv2 client help?
371 Views 11 Replies 3 Participants Last post by  Tufelhunden
i've been trying to fold on my gpu for a couple days now and i keep getting 30-60% through a wu and get this message:
[14:56:51] Run: exception thrown during GuardedRun
[14:56:51] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[14:56:51] Going to send back what have done -- stepsTotalG=15000000
[14:56:51] Work fraction=0.4324 steps=15000000.
[14:56:55] logfile size=18561 infoLength=18561 edr=0 trr=23
[14:56:55] - Writing 19097 bytes of core data to disk...
[14:56:55] Done: 18585 -> 4951 (compressed to 26.6 percent)
[14:56:55] ... Done.
i'm guessing that it thinks my card in unstable. i know for a fact however that it is perfectly stable. can run cod4 maxed out at 1400x900 for hours on end just fine and i played oblivion maxed the other day for over 8hrs with no down time.
any ideas ?????????????????
1 - 12 of 12 Posts
Have you overclocked the card at all? If so just put it down to stock and see if it goes away. Some work units are harder on cards than gaming.
okay cancel that. apparently i am at stock right now. 580/800/1500. um. so now what
What are your GPU temps? Perhaps adjusting your fan speed up will help.
temp is peaking at 60c and fan is at 100% duty cycle.
I'm stumped. Sorry.
hopefully one of the others will be able to help.
Just a thought but have you tried a new driver install for the card?
haven't made it to the 18x.x drivers yet. still on 17x.x i'll give updating a try here in a bit. maybe the current wu will make it through
Actually that may be it. At least try the 181.xx
Originally Posted by crashnburn_819
182.08 just came out. Definitely worth a shot.
Good to hear. May try these as the previous ones didn't work as well for me.
just updated to the newest drivers. running right now. hopefully it works.
Fingers crossed!
1 - 12 of 12 Posts
