I forgot to look at the case specs. One moment.
EDIT: The 240 height is insufficient for that cooler. Would you be willing to change the case out? Either way, I would highly suggest not using an AIO.
EDIT 2: I am also just now noticing that I'm trying to find parts for you using the CA version of the site, however it keeps redirecting me to US pricing... Those links I posted earlier are likely to be quite off.
EDIT 3: Looks like the prices listed are for CA in the previous links
Hopefully final edit
If you are wanting to stay Corsair and don't mind something a little bigger, how about the
200R for a little cheaper. I've had the 400R and the 650D, they were (and still being used) great cases. Still love my medium sized LAN box though, but that is ~$130CA before the $20 rebate.
Nope, got one more edit:
ark.intel reports the CPU video output max resolutions, etc - but it depends on the board. The board you have in your list says triple display is supported, and all three outputs are capable of at least 1200p60Hz
