875P-T question
1179 Views 29 Replies 7 Participants Last post by  shermstix
Hey guys with the DFI 875P-T or 24-pin motherboards: How exactly do you plug a 20-pin psu into the 24-pin psu socket?
1 - 20 of 30 Posts
There are adaptors, yet I dont know where to get em
You can try this, it could work, it could not work, might want to check up and see if you can
You can also use a regular 20-pin psu, I just don't know where to position the plug, as there are 24 holes for 20-pins. Time to match up wires, I guess.
my guess is that it will only go one way...
the molex has two different socket types so that it will only go in one way on standard 20pim molex ... im sure they set it up with that in mind...
Give it a shot with no power on
if it fits just one way then your Good to go i guess...
Im not buying you another one
I think I got it figured out. {crosses fingers and sets another hard drive on fire to appease the oc gods}
Dont spill that beer into the open case
Me personally i have a smirnoff twisted rasberry...
I said Triple Black but got rasberry fruity balls
Ehh i might have to grab a fat tire
They made it so that you could just plug in a 20-pin adapter, you only need the 24pin for the PCI-express card support? or no? I thought I heard that somewhere...
i heard it as well... i heard it plugs in one way and thats it
Hes prolly installing OS now , he got it to fit and is turning it on now and saw that it booted up so now hes getting windows installed and stuff...
He doesnt need us any more
if it blew up his mobo he would be in here screaming about dead mobo...
and asking me to pay for it
OMG, ROFL!!!! HAHAHAHA
You know me too well Spooked! Are you stalking me or something? LOL That is exactly what is happening right now
Booted up first attempt. Unfortunately, I got a DO stepping, hoping for an EO. But its stock vcore is 1.38, and it runs at 3.414, which is nice. At stock speeds, my psu is doing fantastic. All voltages are above spec, much more than with the socket 478 and my old 3.0.
Im not stalkiing you .... i just sit in the Chilis parking lot after hours because im stalking someone else
Yes i know you work at Rock bottom
No TDX yet???
No TDX yet???
Nope. Looks like I am waiting until at least Tuesday, since it hasnt even been shipped yet.
The oc gods weren't pleased with me. I am stuck with the stock cooler, which doesnt seem that bad. I cranked the ac down to 70F, and my system temp is 25 at idle, and cpu was 38. Still doing updates, so I don't know load yet. I'll keep ya posted.
im off to the wild wild west
been playing HL2 but only using hand guns for challenge
and some dude called me wild wild west cause i killed him like 4 times in a row with the 357
some of those peeps dont know how to play, they dont know you can catch with the gravity gun. So they throw at me and i catch and blast em back and they die
anyways im out for abit
Good ol' noobs... its fun with them, once there was so many I was owning them all, and then one by one they left me...
I cannot even begin to describe how pissed off I am. This LGA heatsink/fan is the biggest piece of ***** I have ever seen!!!! I can not even use my new mobo/cpu with this piece of crap. All of a sudden, my temps started to skyrocket. Like, approaching 80C idle. I shut her down, reinstalled the hs with AS5, and still the same thing. The mounting system for the LGA hs is CRAP!!!! I hate it, I hate it, I hate it!!!!! Nothing I do will lower the temps. It is making contact, because the AS5 was spread in a nice little circle, but my temps are INSANE!!! I wrote Intel a nice long letter explaining just how much of a piece of ***** this thing was, and I also told them that if any of my components are damaged, then I will pursue litigation for reimbursement of all costs. :swearing: :swearing: :swearing: :swearing: Now I have to wait till my waterblock arrives, just to even use the system.
Calm down bud...
I know the heatsink you speak of and yes it sucks.. must admit its prety good sink for intel
are you folding or is it just too hot at idle???
i think it sucks that intel doesnt make better heatsinks for there fireballs of CPUs
Maybe they will send you something better
unteill your CPU is Wetter
Alright, I have calmed down. I have also fixed the problem!!!!! I was looking at my stock Intel hs, after deciding it was a piece of crap, and it got me to thinking. The hs uses little plastic pushpins that go through the holes in the motherboard, like the little pushpins that are used to hold a retention bracket on. Anyway, first thing I did was cut those plastic pins off. I then removed the DangerDen mounting kit from my Max 3, and installed it on the 875P-T. Then just mounted the stock hs onto the mounting posts, tightened the nuts, and the results......38-ish idle, 55-ish load
Much better than 70C load
Well, I am happy now until the TDX gets here. Time to lower the multi and stretch my ram. I am pretty sure it will do 265fsb at 2.5,4,4,7. We'll see
Hello copy cat
Glad you got it working mate. Did you find the bracket for the processor really hard to get back into the locked position after the processor was installed? I did - i was crapping myself when i was trying to fix it back into place - it was making all kinds of creaking sounds.
Originally Posted by xms
Hello copy cat
The little lever?? Yeah, I had to use a lot of force, kind of scared me. Everyone has been saying how fragile the 775 sockets are, including me. I just read this at the Inquirer that claims differently.
I just ran Prime 95 for about 10 hours at 260fsb, 14X, and timings of 2.5,4,4,7. Cpu speed is 3.65, on stock voltage. Working pretty darn well. Can't wait till my TDX gets here! The weird thing is, I set the vdimm to 2.9volts, and it is reading 3.7
!!!! That has to be wrong, as my ram isnt even hot, and it would most certainly be fried at 3.7volts. I am trying to find the vdimm check point with my multi-meter.
Thats really wierd? Where are you getting those readings from, coz as i said, i cant get a vdimm readout of my one??!?!?!
1 - 20 of 30 Posts
