Originally Posted by brettjv
Fill in your system specs, first of all.
Secondly, the problem could be the card, or it could be the card's drivers, since you changed drivers at the same time as you changed cards, right?
I have a similar issue right now myself with my rig, but it only occurs in Windows 7, and not on my XP install. It's not just happening in games either, I get it when I'm listening to music as well. Heck, it's even there when the Windows welcome sound plays.
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7100) (7100.winmain_win7rc.090421-1700)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 2048MB RAM
Available OS Memory: 2046MB RAM
Page File: 1454MB used, 2638MB available
Windows Dir: C:\\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7100.0000 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS 512
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS 512
DAC type: Integrated RAMDAC
Device Key: Enum\\PCI\\VEN_10DE&DEV_0600&SUBSYS_C8423842&REV_A 2
Display Memory: 1266 MB
Dedicated Memory: 499 MB
Shared Memory: 767 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: Sceptre
Monitor Id: SPT2011
Native Mode: 1680 x 1050(p) (59.883Hz)
Output Type: DVI
Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver File Version: 8.17.0011.9562 (English)
Driver Version: 8.17.11.9562
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 11/20/2009 20:34:54, 9333352 bytes
