8800GT aftermarket cooling
347 Views 5 Replies 4 Participants Last post by  Aaron_Henderson
Just wondering if the 9800GT's use the same mounting holes as my 8800GT's do. I want to know if this will fit. They have an 8800 version but it says it's for 8800 G80 core which I am pretty sure uses different mounting holes.
http://canadacomputers.com/index.php...647&cid=FN.251
1 - 6 of 6 Posts
Yes it'll fit I have the same cooler on a g92 8800 and also on a g92 9800
also use the accelero on a diff 9800GT
That should fit on the 8800GT 512... the 9800GT is just a re branded 8800, so......
This DuOrb is a great cooler for the 8800GT.. you wont see temps past 55c with it, and its nice n quiet.
http://canadacomputers.com/index.php...286&cid=FN.251
Thanks for the quick response, I think I'll be going with two of these bad boys to replace the stock cooling. They look bad azz.
I just don't like the look of the Duo ORb, these look sweet (no lights!) and beastly, and seem to have about the best performance. Kind of pricey, but still cheaper than Zalman VF1000, especially for what you're getting.
1 - 6 of 6 Posts
